Discuss prepping a floor for Amtico in the UK Tiling Forum area at TilersForums.com.
TeeKay
Hi,
I'm loooking for advice on prepping a floor ready for laying Amtico. I'm laying Amtico Contour tiles which are 4mm thick and more rigid than normal Amtico.
I've done a lot of reading of this and other forums/websites but seem to have more questions than answers. As this is clearly the most informed of the forums I thought I'd look to you for guidance.
The floor is for a kitchen and recently added conservatory that joins onto the kitchen.
The kitchen is nominally 20sqm, the floor is concrete with screed, topped with a thin SLC and finally a cushion vinyl floor covering that just lifts off.
The SLC is not IMO smooth enough for laying Amtico though it is pretty level.
The conservatory which is a new addition is a similar size with concrete floor and about 75mm sand/cement screed which is reasonably level but is beginning to hairline crack in the middle now that it is coming to the end of its drying out.
Around the cracks it sounds slightly hollow when I tap it but I guess that is what one might expect.
1) I was going to go for a water based SLC but now that it is cracking I'm considering using latex. Your thoughts?
2) Should I do anything about the cracks like rake out a bit and epoxy?
3) Their are so many makes of SLC, and they vary in prce and availability. Currently I'm looking at F Ball, Cementone or Ardex. Mapei is difficult to get unless your in the trade and I'm not. Cementone I'm put off because the tech guy said use PVA not primer, probably because they don't make a primer. For the beginner which is easiest to use?
4) Mapei tech support guy said to use a copper sanding disc on the conservatory floor. Is this really necessary or will a good brush with a hard broom followed by a primer be adequate?
5) Should I spend £40 on a spikey roller or should I accept that I will have to work it with a carborundum stone anyway and just buy a stone, or should I buy both?
6) I want to lay the SLC in two halves. Assuming this is OK then should I fix a batten down and lay the SLC to the batten then continue, or just feather the edge ready to continue?
Sorry for so many questions but I've never laid SLC and I do want to get it right. Quotes to get the job done professionally are around £3500. I reckon I can get the tiles, HT adhesive and grout for around £1200 so I have to assume its not a simple job. But as I can't afford £3500 I have no choice but to do it myself.
Thanks in advance,
Tim
david campbell
hi there,i've spoke to 2 peeople who have problems with amtico floor being laid directly onto concrete,one of them has had the amtico people out every year for the last few years to see why parts of her floor have kept coming loose(they can't give a definate answer to why this has been happening),however people that have ply lined the floors first have not had any problems,just something to bear in mind before laying this!
988
i fit karndean and i would not expect a diy to be able to smooth a floor out to the required standard for karndean or amtico
1) I was going to go for a water based SLC but now that it is cracking I'm considering using latex. Your thoughts? WATER BASED WILL BE FINE F BALL IS GOOD UTZIN BETTER
2) Should I do anything about the cracks like rake out a bit and epoxy? NO FILL WITH SKIM COAT F BALL DO ONE
3) Their are so many makes of SLC, and they vary in prce and availability. Currently I'm looking at F Ball, Cementone or Ardex. Mapei is difficult to get unless your in the trade and I'm not. Cementone I'm put off because the tech guy said use PVA not primer, probably because they don't make a primer. For the beginner which is easiest to use? MAKE SURE YOU PRIME THE FLOOR AFTER YOU HAE GIVEN IT A BLOODY GOOD CLEAN ALSO GET RID OF ANY PLASTER RESIDUES
4) Mapei tech support guy said to use a copper sanding disc on the conservatory floor. Is this really necessary or will a good brush with a hard broom followed by a primer be adequate? BROOM HOOVER SOFT BRUSH HOOVER
YES A SPIKEY ROLLER ALSO A COMBINGTROWEL WITH 5MM NOTCHES ALSO YOU WILL PROBABLY NEED A STONE
6) I want to lay the SLC in two halves. Assuming this is OK then should I fix a batten down and lay the SLC to the batten then continue, or just feather the edge ready to continue? NO ONE HIT
YOU PAYES YOU MONEY YOU TAKE YOUR CHANCE
where are you based
grumpygrouter
Just as an aside to this, Mapei Fiberplan dries almost billiard table smooth!
TeeKay
Thanks for taking the time to reply. It is appreciated.
Lets hope I can prove you wrong :).
I've never heard of Utzin - I did a google and found nothing. As for stopgap I have found a friendly supplier that will do me stopgap 300 for £17 inc a bag.
I live in Guildford, Surrey.
TeeKay
Unfortunately I can't source Mapei cos all their local distributors only sell to the trade. Maybe someone knows a DIY friendly distributor near Guildford or Maidenhead.
If I'm going to prep 40sqm of floor and fit Amtico to it you'd have thought that almost entitles to free membership to the club :)
DHTiling
Tile giant or Tile it all will get you some mapei fibre plan...:thumbsup:.. thell them tilers forums sent you..
In the chats i have had with a kardean and Amitco floor layer you will need a different glue for conservatory use, so that it copes with the heat.... expansion contraction sort of thing...
Ajax123
1,213
Lincolnshire
I live in Guildford, Surrey.[/quote]
Its spelled UZIN
www.uzin.co.uk
I assume your screed is cement:sand and not Anhydrite otherwise prep materials will need to be different
If anhydrite - Uzin PE360 primer and NC110 leveller (other brands are available)
988
dyslexia strikes again uzin thats the one
high temp glue for connie floors plus you will need a hand roller as well
TeeKay
Its spelled UZIN
www.uzin.co.uk
Thanks for the Uzin link I'll check them out. As for the screed, it is just a sharp sand/cement screed.
Reply to prepping a floor for Amtico in the UK Tiling Forum area at TilersForums.com
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm...
