jonny2tanx
Hi all. I am trying to finish my house extension that has been going on for almost a year, and tiling the ensuite is the final job. I am using 600x300 ceramic tiles laid landscape and in straight rows. I have used MS Excel to make a grid of tiles and also the dimensions of the walls with window, door and bath (set column and row widths to the same as the relevant dimensions in cm using the pixel measurement), and have laid the tile grid under the wall grid and moved it around to see what works out as the best layout. I can get it to work quite nicely with straight cuts around the window reveal rather than having to do L shaped tiles, but I end up with a gap of about 1.5cm between the top of the top full tile and the ceiling - in other words the distance from the inside of the window reveal to the ceiling is 31.5cm whilst my tiles are 30cm 😳
I have tried moving my "tile sheet" round behind the "wall sheet", but can't seem to get a decent result - If I make it so that a have a horizontal joint half way between the top of the reveal and the ceiling, I then end up with an approximately 12cm wide strip above the bath (and 4 L shaped cuts around the window). The other half says 'just ignore the gap at the top of the wall and fill it with grout between tile and ceiling (more out of desperation to see the job finished, I think) but I don't think this will look right.
What am I best doing?
Plan A: stick with the original layout and have the gap or
Plan B: have a horizontal joint 16.5cm or so from the ceiling, and have a 10cm high strip around the top of the bath? The bath runs across the room directly in front of you when you walk into the room.
It doesnt look at all bad when I put my "tile sheet" behind my "bath wall sheet" - in fact it balances the wall vertically, with the 12 cm strip above the bath and the half tile (or thereabouts) next to the ceiling. Is the 12cm strip above the bath enough, do you think? Trouble with this is the 4 L shaped cuts that introduces the possibility of error with an amateur like me. I can get around this my moving the tiles half a width sideways (having the joint in the middle of the window rather than mid tile in the middle of the window, so I end up with straight vertical and horizontal cuts), but then end up with a 10 cm sliver in the corner of the room (but this may be hidden by the towel rail and is on the wall where the door is).
The 'Works Manager' says just get on with it but I have read so much here about the importance of correct setting out that I need to get it right. Sorry about the wordy explanation, but any advice would be appreciated.
I used to be indecisive but am in 2 minds about that now
