Discuss How To Cut Curves With A Wet Cutter in the UK Tiling Forum area at TilersForums.com.
H
heidigrl43434
Hiya,
We bought a wet cutter because we are using really large thick tiles in our bathroom.
It's perfect for straight lines, however the instructions that it comes with does not make it clear how to cut curves. It just says to lift the wet guard and use the top of the saw to cut the corner.
I can't imagine how this would be done. Can anyone give a better instruction?
Heidi
Spud
it is a difficult question to answer
what type of curve cut do you wish to make? as an out swinging curve cut is cut by cutting tangents ( several straight line cuts) and gradually you start to form the curve leaving less and less of the waste on the tile an internal curve cut can be cut by slicing lots of cuts out of the centre and this will would be repeated until all the waste has been removed slowly turning the tile with each cut to follow the curve .
There are specialist grinding blades designed for cutting curves which may be fitted to an angle grinder hope this helps
doug boardley
nice one whitebeam, only thing i do different (and this is being picky!) is use my nippers like a little toffee hammer to knock off the segments,!
DHTiling
G has already seen it...they do a smaller version as well doug...go onto utube and type gemini XT and the little taurus is on there as well..
White Room
Use a scoring blade/rubi blade embedded into an old file handle and do a score free hand on the marked line for a curved cut onto a tile which helps when breaking the tile peices which have been wet cut
Reply to How To Cut Curves With A Wet Cutter in the UK Tiling Forum area at TilersForums.com
