Currently reading:
why prime the back of the ply and not the front?
Discuss why prime the back of the ply and not the front? in the DIY Tiling Forum area at TilersForums.com.
Hey folks, ive just laid 12mm Marine ply on my bathroom floor in preparation for tilling, its screwed down on 200mm grid formation then i primed the ply with SBR bond as i have done in the past. Today i mixed up sovereign tile adhesive and glanced at the instructions which stated i was to prime the back of the ply and not the front????? why.... this goes against everything i have learnt about tilling, slowing the suction rate etc and why on earth would you ever need to prime the back. Can anyone explain?
Dumbo
After having a discussion on priming on this site I was told by some members bal said not prime ply if using rapid flex . They were correct that is what it said on spec sheet . I then rang bal the next day and asked why not and they then said it would be OK to do so . So where I'm getting to is this I always prime everything and if someone on here wants to give a reason not to I will then take it up with the relevant technical company .
Ok thanks Julian, i thought it was standard practice. If the suction rate is not controlled with cement render and plaster than you end up with a crumbly mess. I thought a longer cure gave a greater bond and strength, you know yourself if you get adhesive on your jumper it dries and crumbles away! Do you think it will matter that i primed the ply when i shouldnt have? ooops
Dumbo
Absolutely no problem as far as I'm concerned always prime . But as above never Tile directly to ply as I have seen many failures over the years and lots of brown grout .
Reply to why prime the back of the ply and not the front? in the DIY Tiling Forum area at TilersForums.com
