What trowel notch size/shape?
The Karl Dahm trowel is based on a thick-bed solid-bed trowel. So before they had the notches in they were just a half round notch. But after studying how the adhesive is pressed around as you apply preasure and do the wrist twist action thing, a few manufacturers found that sometimes the half round alone didn't actually give 100% coverage 100% of the time. So a few manufactuers have now started to make thick-bed solid-bed trowels with the notches in them which helps you lay the tiles quick as you can assure yourself that they have 100% coverage pretty much 100% of the time.
Very very good trowel design.
10mm round notched trowel for the floor, you will need a 10mm wheel in the cutter score the line with heavy presure use a quick snap action drill problems use diamond tip water cooled, you don't say if the tiles have a thick profile on the back. The deeper it is the bigger notch trowel you will need. Use multiflex adhesive. If polished porcilin then you must seal them first before grouting
SonOfSylvanus,
calculator,
SonOfSylvanus,
calculator,
