Discuss Uneven wall bathroom tiling in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Shezzaar
Hello guys,
I am wanting to know if it is possible to tile directly onto this wall or not?
My other options would be to replaster, one or both walls, or replace the plasterboard wall.
It is for a bathroom, with a shower being in the corner, so both wall wills be effected.
See photos;
Photo 1 is the plasterboard wall with insulation behind it.
Photo 2 is a plastered brick wall, that I could either reskim it all or patch it up, thoughts?
Thanks in advance
jobdone
Repack the plaster board and dry line the other wall, tank and you will then have good walls to tile
Plasterboard is very cheap, extremely easy to remove/replace, and can be tiled directly onto, for an excellent tiled finish. Brick/block plastered walls can be repaired by render.
Reply to Uneven wall bathroom tiling in the Canada area at TilersForums.com
laattaana
