Discuss Under tile heating in the UK Tiling Forum area at TilersForums.com.
U
Uheat
This is not a regular question we get asked and the best solution would be to as suggested take up and overboard the floor first. Rather than Ply you could use our 10mm Thermopanel http://www.tilersforums.com/electric-underfloor-heating/19750-what-great-deal.html
How are the cork tiles stuck down?
If stuck down using a solvent based adhesive then the heat could cause the tiles to come loose!!
If you want to keep the tiles down i think you best option would be to overboard the cork with a min of 6mm Thermal Construction board. Underfloor Heating | Floor Insulation | Uheat
Another thing to think about which is not my area...Is there a Tile adhesive that will stick to cork?
Loose wire is generally better in smaller awkward shaped rooms or with a lot of obsticles in the way.
Please have a look at www.uheat.co.uk for some great products and prices or give me a call on 07887 545757 and i will talk thru things with you
hope this helps
Time's Ran Out
Cork tiles need to be removed you dont always need tile backing boards sometimes underfloor heating companies sell them as an extra when they are not needed. Try talking to <REMOVED ADVERTISING> tell them your from the tile forum for extra discount.
Although this thread is over 3 months old are you advising this member to remove the cork tiles and tile on what? - the floorboards.
Why would an underfloor heating co. advise tile backing boards if not needed. Thermopanel would obviously be a good product to use in this case, as a insulation/backer board ,and every thread IMO should be treated on its own merits. :thumbsup:
Timeless John.
Reply to Under tile heating in the UK Tiling Forum area at TilersForums.com
