Stef
Did you get any photos as you were repairing mate, never even knew UH could be repaired. Good post![]()
TJ I never took photos I forgot.
I never went right through the cable I only nicked the edge & exposed the outer earth wires.
Think of a co ax cable for a TV, you have your live & neutral running through the middle & then insulation then your outer wire is the earth then the outer insulation. The shrink tubing is only to stop moisture going into the earth wire.
If you did go through the entire cable then it can still be repaired, it's Ezewarm heat mat I use & they will send out a full repair kit if needed.
