Currently reading:
Tiling onto Paramount board
Discuss Tiling onto Paramount board in the UK Tiling Forum area at TilersForums.com.
Gazebo
Hi all,
I am new to this forum and have been reading some of the posts which are very in formative, i am after some advice (it will probably be the 1st of many questions i will ask as i realise how important it is to use the correct adh/grouts and techniques but alas i am very confused.) I am in a situation where i was going to remove the plasterboard from a stud wall and and replace with marmox 12mm board, (fixed with stainless steel penny washers etc) but upon removing the existing tiles which came off easily thankfully someone tiled unto wallpaper, i have discovered that the wall is paramount board (Ex council building about 1970) the board is in good condition but which adhesives/primer/grout would be best to use, it is for a bath surround. also i am able to use marmox board to build the shower enclosure but which adhesives/grout etc is most suitable/easy to use on this.? sorry for such a long description but i am hoping this well help someone to help me.
Thanks again for all being very helpful in this forum (creep creep)
Gazebo
Hi Dave, sorry forgot to mention tiles are ceramic 300x250mm wall tiles, in the past i have used Bal white star on plasterboard but have not primed it prior to tiling, also i am using marmox 12mm backer board what adhesive would you advise for this size tile.? (is marmox worth the extra expense in a shower enclosure or is green plasterboard adequate.?) also when fixing marmox the pastic washers they provide seem to remain very proud of the board, has anyone experienced this.? i have started to use stainless steel penny washers and screws. seems fine but what is the concensus.?
be good all and by the way my wife has discovered me reading this forum on the toilet, am i the only 1.?
DHTiling
Might find it hard to get my pc( desktop) into the toilet...:lol:...
As for adhesive with those tiles...if you prefer using a suitable dispersion adhesive then it will be fine with that size tile....If you are going to use the marmox boards in the shower then you will need to tape the joints as well, or you could use plasterboard and apply a tanking membrane...:thumbsup:
Reply to Tiling onto Paramount board in the UK Tiling Forum area at TilersForums.com
Hi, long time lurker, first time poster. Over the years I've used the good advice that I've read on this forum but with my current project I am a bit stumped. I am renovating an ensuite, it's...
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
