Tiling Mosaics on Uneven Surface
spiidey
We're halfway through tiling a combination of mosaics and ceramin tiles.
In the picture below, along the vertical strip of blue mastic, the wall drops back about 2-3mm from left (of blue mastic line) to right (of blue mastic line).
What is best way to smooth this out, so that we have a flat, flush surface to tile on? The tiles going onto that blue area will be a continuation of the mosaics from below therefore we need the surface to be as flat as possible.
We need the surface to be brought forward 2-3mm from the blue mastic line, to the adjacent wall on the right hand side (about 2 feet away therefore need to smooth out an area approx 8 square feet)
Could we apply tile adhesive, let it dry, then sand it flat/even, and then start tiling the mosaics using a fresh layer of adhesive on top of the dried adhesive?
If you are using a cement based adhesive then you could do it that way or take a piece of wood and notch out the depth ot the mosaic plus a few mm for adhesive. Spread the area to be mosaic and use teh wood to set the depth. Let dry and then tile.
As above. Some pics.
spiidey,
andyq,
spiidey,
andyq,
