Tile Trim Size?
Stealth
Hi
I going to be fixing some ceramic wall tiles with a thickness of 11mm.
I want to use some PVC trim around the window reveal. What size trim should I be using? (I'd prefer to use the smallest size I can get away with). Many thanks
try 12mm mate but in plastic they look like giant marshmallows thats ize square edged chrome is much nicer if you can afford it. never used anythin bigger than 12mm not sure you can actually get it
the trim depends on the tile thickness, you cant prefer a small size, you have to use whatever fits your tile, if your tile is 10mm thick then it will be a 12mm, if its 5mm then a 6mm trim, try not to get a trim that is too small, the tile will lip it and show a bad edge,
goodluck :thumbsup:
This is 12mm ply with tiles
Tile Trim Size?
Stealth,
Deleted member 1779,
Stealth,
