stone blade for grinder
Mark Frost
Hi guys.. Now im starting to understand mofe about the blades we use, I want to purchase a blade only for stone.. what would you recommend at a reasonable price thanks
🙄 wheres this sense of humour at work 😛
Yeah, you don't want me to answer that! 😀
Ok so the real trick is, one blade, one material.
Nearly all blades will work with stone cos generally it's a soft material.
But if you use a blade on porcelain and then stone, then back to porcelain, you'll find it's not the same blade.
So one blade, one material. Then you'll get more consistent finishes.
Is this a partnership I see blossoming ?
Vacuum brased blade from
Ats for most soft stone
Mark Frost,
Flintstone,
Mark Frost,
Flintstone,
