Discuss Some opinions? in the Canada Tile Advice area at TilersForums.com.
E
Eduardo
Glass tile from China. 2012-05-14 13.38.29.jpg 2012-05-14 13.31.52.jpg Was fitted with good adhesive,grout with flexible grout,after two months I was called by the client.Fortunately the bathroom was renewed and the payments made by builder insurance.I remember when I saw this therad http://www.tilersforums.com/tiling-forum/66160-good-paper-two.html . Can be about the use of recycled glass in tile?I found nearly 100% cover in this tile,I have not found an explanation for me ..
DHTiling
It does look like impact shelling , but it could also be a fault in those 2 tiles and thermal/moisture expansion has put stress on said fault and shelling has occurred..
E
Eduardo
These 2 tiles are in middle of wall,not near the corner, or subject movement due to change of temperature, humidity,hot water.
Spud
Glass has a far higher coefficient of expansion than ceramic stone and porcelain so it may be that
E
Eduardo
I think yes,but why 2 tiles in the middle of walls?Usually you can see expansion on a line from bottom to top, or horizontal....Anyway a line, not just one single tile.
Points
1,068
we work nationwide .
If you read the papers that i posted on the forum yesterday , you will understand that Chinese glass is often recycled glass and thus can have poor quality glass in the firing as old bottles and the like all get re-cycled , also could be the same as dave gary said above, which was all covered in the papers ............
Reply to Some opinions? in the Canada Tile Advice area at TilersForums.com
  • Sticky
