Hi, Further to the question asked by Jason35 above, can I ask for some similar advice?
I have to tile my son's 2mx1.7m (6'7"x5'7"), part of the floor is taken up by a 900mm (3') quadrant shower base. The existing floor is part large chipboard T&G type panels nailed down and the rest is plywood sheet screwed down. I intended to sand any uneven joints and cover it all with 5mm ply then seal it with yacht varnish to seal it, before tiling with 330mm ceramic floor tiles. Now I am not so sure!
Can I ask for some advice on the following:-
1. Should I also screw down the older nailed down chipboard floor?
2. Can I tile straight onto the floor without covering it with the 5mm ply?
3. If I have to cover it with 5mm ply, should I glue or screw the ply down?
4. For a small area like this what would you recommend for sealer/adhesive/grout?
Looks like the tiles will be coming from B&Q and it is pot luck on the night when asking for advice in-store. I would really appreciate any advice as tiling is not one of my favourite DIY tasks, I'd rather paint first and I hate painting! Thanks in advance.
Regards,
Ron.
