Discuss Silicone joins at bottom of wall profiles in the Canada Tile Advice area at TilersForums.com.
R
rboy_44
Thanks but specifics would be more helpful, like do I follow the instructions or not? And if I do then do I just smooth the new silicone into the cured or butt it up against it? Or do I not follow the instructions and do something else?
https://merlynshowering.com/wp-cont...oor-fitting-instruction-MER-01-New-handle.pdf
Tried Merlyn and they’ve been next to useless. They suggested I do some research into how best to join new silicone to cured silicone and sent me a link to a specialist adhesive that I could try!
I’ve taken out the doors and removed all the existing silicone (as the original installer did a crap job with the install that resulted in leaks) and am about to reinstall so would quite like some certainty that I’m doing the right thing here.
Cheers.
Dumbo
Thanks for your comments Plan Tex Tiling - appreciate it.
jcrtiling - did you seal down the internal wall profiles and smooth the silicone into the cured silicone on the tray (as per instructions)? Or did you only seal the outside of the profiles?
I sealed inside and outside because im a rebel like that . Your main concern is about old and new silicone it wont be an issue that is the point i was trying to make about sealing tray one day and fitting a screen the next . It happens all the time tilers finish tiling includuding siliconing and then plumbers come and second fix the bathroom including fitting screen .
Reply to Silicone joins at bottom of wall profiles in the Canada Tile Advice area at TilersForums.com
  • Sticky
