Shower Tray Riser kit install
Hi,
I am doing an en-suite at the moment and will need to install the shower tray which comes with a riser kit. Now normally these things are much like bath feet and have holes in to screw them into the base of the shower tray (or wooden support)and screw the bottom of the feet to the floor.
This one has plastic feet with sticky pads to attach them to the base of the tray and no holes to screw into the floor.
The feet are actually simular at the bottom to those you get on kitchen cupboards. I have seen simular feet to this but they were the screw in type.
So firstly would you trust the sticky pads and assume that the downforce of the tray and anyone in it will keep them firmly atttached to the tray ?
then more importantly, how would you fix the tray so it cannot move without screwing it into the floor?
FYI, shower tray is stone and the riser kit is like this:
(Victoria Plumb) going onto a boarded floor.
Orchard Riser kit for rectangle and square stone shower trays 1400mm and over - https://victoriaplum.com/product/orchard-riser-kit-for-rectangle-and-square-stone-shower-trays-1400mm-and-over
Those sticky pad kits are super sticky and are fine to use. I usually mark where the feet will touch the floor and blob a bit of rapid set and bed the feet into it too.
I don't like that flimsy leg things! Prefer to frame out with wood that is glued and screwed to floor, then tray secured onto frame with flexi adhesive.
Thanks guys, I'll go with the sticky pads and a bit of quick set under the feet.
Yes I was thinking a wooden frame might be an option but seems ok so I'll go with it.
Did customer specify this? Stone trays and riser leg kits do not mix in my experience and must be battened around the edges to the wall as the main support with the legs only acting as additional centre support. As mentioned above if you're going to quick set to aid make sure surface is primed if it's a chipboard floor before laying down rapid set. Otherwise why don't you drill holes yourself in the base of the legs and screw down?
These kits are supplied by the tray manufacturers. and to maintain any form of guarantee you should fit following their instructions.
Hi
Yes it is supplied by the manufacturer and I have followed the instructions. The instructions didn't say anything about attaching to the floor. Which is why I asked for suggestions.
All looks good though. The base was marked with the position to fix the pads so in this case they must be designed to go with a stone tray.
Thanks for the advice.
Tanking and Wetrooms
bolts,
Tim Saunders,
bolts,
Tim Saunders,
