Set up and prep?
Cheers Mike,
Am I to assume that I dont need any additive for this product, just making sure as i'm laying it on 6mm insulation board 🙂
Is there any reason why you can't stretch to 10mm insulation boards? They will be far more effective that the 6mm boards.
Daz
Daz
No other reason than I have 6mm in my living room and wanted to keep the same level as my oak floor at the threshold, will 10mm make that much difference mate?
Are the tiles plus adhesive likely to be the same thickness as the wood floor? You may have some tolerance there. Also a transition strip between the two floors will disguise any height differences.
Good luck,
Daz
Yeah very true and it will only be a minimal mm or 2. .I will look into maybe going with the 10mm. I'll have a read up mate, cheers
Set up and prep?
slikt,
slikt,
slikt,
slikt,
