Seals around the baths
Silicon is a beter method as those bath seals attract the scum off the soap etc and eventually stinks and they split at the seal point in time as well..........dave..
Hello Jimmy - Ultimate in seals teleseal 10 - get it at b and q.Can be fixed to wall before tiling and after tiling.Has a special flex that moves up to 10 mm if the bath moves.Expensive but works .I fit baths all the time and just add it to the quote.Looks good to as mitred joints are glued white.Kit comes with adhesive and everything you need.Try it.
Silicon every time, if you ever have to renew it its easy, those seals when fixed thats it, you would have to remove tiles what a nighmare.
At £30 ago they want to work..lol lol.....give me Silicon any day much neater finish.........dave..
TeleSeal10® - The Ultimate Seal - FREE DELIVERY!!!
Peg your tiles up with Rubi wedges, about 2mm, Silicon likes to have a gap to go into, not just a 90 degree angle, thats the problem with Silicon, if you know how it likes to be used, you'll never have problems. Also, if it is a acrylic bath, fill it up with water before siliconing, that way it will move with the eventual weight of water and human.
Tags Tags
usa
jimmy495,
andy-p,
jimmy495,
andy-p,
