Discuss putting a strip of 4mm glass mosaic between 6mm tiles in the UK Tiling Forum area at TilersForums.com.
John Wallace
I'm tiling my bathroom, which is in a corner of the house with dry lining on the two outside walls. The plan is to tile all the walls floor to ceiling with white tiles (6mm thick), with a strip of glass mosaic (4mm thick) a little below eye level. As a result of some uneven plaster, and a 1 mm change in depth where I put aquapanel behind the location of the bath and shower, the row of tiles below where the mosaic strip is to go is hanging on up to 4 mm depth of tile cement. When I tried putting the glass mosaic strip in today, it was going to need up to 6mm depth of cement to mount flush with the main tiles. I found that too difficult, so abandoned the attempt, and plastered about 2 - 3 mm depth of tile cement (BAL white star premix) on the wall where the mosaic is to go, and am currently waiting for it to go off (it is still very soft after about 4 hours!). This seemed the only practical thing to do. However, if this is a really really bad idea, would someone please let me know before the cement hardens, so that I can scrape it off (provided, of course, that you can provide a better idea).
I
Ian
You would have been better off using a rapid setting cement based adhesive for this but, you should be ok with the whitestar, just double check what the recommended depth is on the tub, can't remember if it's 3 or 6mm for whitestar.
Sent via Tapatalk for iPhone
438
Balham SW12 0NJ,
I think its 3mm max, tiles max size shouldn't exceed 300 x 300 too, I would change your adhesive to powdered cement base one, and it drying slow too completely sets in about 20 hours
Good luck
Brian the Tile
973
north wales
think i would scrape it out and make sure you dont let any set on the face of the tile and then get some white rapid set powder adhesive mix pretty thick and bob should be your uncle,good luck:smilewinkgrin:
John Wallace
This is proving to be a very tricky job. I reviewed the specs for whitestar (max 3mm) and rapidset white cement based adhesive (2 - 8mm), but on reflection, the problem is not the depth. Cement based adhesive sets by hydration of tricalcium silicate, which happens by virtue of being wet, so it doesn't matter what area of tile covers it up. Whatever the adhesive is in whitestar sets by exposure to air - not idea what the chemistry is, but guess it might be drying out and/or oxidation, both of which would start at the edge of the tile and work inwards (though drying out could be into the wall, and the substrate of the tile). I suspect the 3mm limit on depth for whitestar is because it would take forever to set if any deeper. Glass mosaic is made of 20mm squares, so there is no point at which the cement is more than 10mm from the edge of a square. On that basis, I decided not to remove the 3mm layer I have already put up, but to pursue the idea to its logical conclusion (put another 3mm on top and stick the mosaic on it). It didn't work. On inspection, my tile cement spreader has grooves in it that are 6mm deep, 6mm wide, and 12mm pitch (i.e. 6mm gap between them).There were two problems when I applied the mosaic strip (1) with no pressure it sank deeper than the tiles below it, and (2) the tile adhesive was as inclined to come up round the edges of the 20mm squares rather than spread underneath them. After 3 attempts (with a thorough wash of the strip of mosaic between them), I scrapped the strip of mosaic, and spread the tile cement out to make another layer about 3mm deep on top of what I have put on already, so now have a layer of tile cement about 6 - 7mm deep, that I have sanded do a smooth level finish. I have just sized up a sheet of mosaic, on this, and it looks as if it will fit nicely now, only its no good putting 6mm high ridges of tile cement at 12mm pitch behind them. Am about to cut an improvised spreader tool from 2mm ply, using something like 3mm grooves at 6mm pitch.
R
Rich
Wow. What a job. If the mosaics are thinner than the field tiles, I use a mosaic packer. I think they are caller 'Mosaic Pro mosaic spacers'. They are great, they sit behind the mosaics to bring them flush with the rest of the tiles. Bit late for that now. Sorry
John Wallace
Thanks, Rich, that sounds like exactly what I need. I have finished the 1140mm strip that goes from the window to the corner, and am quite pleased with the result, but even having worked out a way to do it, was not looking forward to laying up 5 - 6mm of tile cement (probably in 2 layers) all the way round the room. I'll look for the spacers.
John Wallace
AliGage, thanks for the advice. Can you explain why white star is bad on glass mosaic tiles? Unfortunately, I have already done a strip with it, which I am quite pleased with, and at the back of a shower, where it is not unlikely to get wet. It is not impossible to remove it (at worst about 3 hours work if I scrapped the existing tiling above bath level and replaced the sheet of aquapanel entirely), but I don't want to do so without a compelling reason.
Reply to putting a strip of 4mm glass mosaic between 6mm tiles in the UK Tiling Forum area at TilersForums.com
