Preparing a Brick Wall for Tiling
Hi, I'm retiling the walls in the pictures which is a shower above a bath - one wall is stripped back to the bare brick and the other is back to the plaster, which is sound.
To prepare the brick wall, I'm thinking of using a 6mm hardie backer - they recommend a grab adhesive but would anyone use a bed of tile adhesive?
With either method does the brick need to be primed?
Or would anyone suggest using a different type of board?
For the plastered wall, can it be tiled straight on to, or should i put a backer board on that too?
The tiles are a 400mm x 250mm ceramic tile
Thanks in advance
DIYER44,
pete f,
DIYER44,
pete f,
