Discuss Platinum tiling tools in the UK Tiling Forum area at TilersForums.com.
tile55
Hi chaps, and chapesses do any of you guys use Platinum tiling tools, and what do you think of them.
Brought the adhesive spreader and nibblers early last year and have rarely used them, I find them slightly too heavy than what I'm used to, so only use them occasionally.
The adhesive spreader works fine though, and the scraper part is a good touch, [link removed ]Platinum Notch Trowel - Platinum Tiling Tools - Tiling Tools, trowel, notch trowel, platinum trowel - link removed[/url]
the nibblers I'm not too sure about they seem a bit over-engineered too much gooing on with their construction. link removed]Platinum Tile Nippers - Platinum Tiling Tools - Tiling Tools, tile nippers, platinum tiling tools - link removed[/url]
What about you guys in the Us, are these the preferred tools over there.
Dan
Admin
5,039
1,323
Staffordshire, UK
Just bumping some of the tiling tools related threads. This thread might not be current discussion, if it isn't, just ignore this, and it'll soon drop off the list. Don't worry if you bring it back into current discussion yourself though, the content within it could be useful for somebody. So feel free to add to it if you have something valuable to add.
Reply to Platinum tiling tools in the UK Tiling Forum area at TilersForums.com
  • Question
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
