Discuss News Raimondi in the Tile Tools | any Country any make any model area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
L
LM
I had a sample a while back. They look ok but I worry about scratches. And you have to wind out the broken thread afterwards!
Wedges will scratch a vulnerable tile also so for me that concern is cancelled out whilst comparing to RLS. The winding out doesn’t seem to be that troublesome. Have you e er used that auzzy ATR system, now that’s what you call a pain in the arse for work load.
I
Italy
I'm quite disappointed with this purchase.
1 problem: power raizor that vibrates, after 2 months I have not yet
had news if it's normal like that or not.
2 problem: the loading pistons of the suction cups,
if you place the bars vertically, they go out alone and fall into the ground.
answer from raimondi: impossible that they fall alone.
3 problem: the locking nut in the breaking clamp was missing.
I put it.
4 problem: the slides of the suckers pressure lancets
come out. (problem solved with glue).
I did not expect all these problems with raimondi, quite disappointed.
www.youtube.com/watch?v=R7JSIG9PA38
www.youtube.com/watch?v=8xvthFusklY
Antonio I found the power Raizor vibrates, it was reduced by always using spanner to tighten locking nut on blade, after a number of times using spanner, vibration decreases.
I then changed grinder, it was a mistake! began to vibrate again.
Vibration was decreased again by continually using spanner.
And now I have gone back to original grinder and I must decrease vibration again. :(
It is not a good solution, but it appears to work s little.
The main spindle that carries blade should lock in to housing to become more stable, alas it does not.
Reply to News Raimondi in the Tile Tools | any Country any make any model area at TilersForums.com
Apatel
