Mosaic backing sheets
Hi Ali,
I've just used them this week on mosaic border. The customer was offering to buy them so i thougth i would give em a go!
Ideally they are meant for full sheet use i think, but they did work well for a small border between field tiles. It takes bit of messing to cut them down with a knife, but a sharp blade does help!. I stuck the full sheet to the plastic backer then flipped it over and cut them into the strips. It certainly does make it easier to get them on the wall, but you do need a thicker bed of addy to make sure you get enough on the mosaic.
The only little snag i noticed was that the plastic sheet was a little bigger than the mosaic sheet i was dealing with, so in some cases i ended up with a bit of the plastic backer stuck out beyond the mosaic, which may or may not cause a little problem if that forces your mosaic to sit higher than you want, or the field tile above wont sit down low enough.
The adhesive of the plastic sheet is pretty strong and did hold the mosaic in place, but i think you still need to put the mosaics on with rapid set and allow to dry before you can build up off them. Unless you can use pins all the way along under your next tile up so you can crack on.
they are a bit pricey, but on a small job i would be tempted to use them again.
hope this helps guys.
I use the dog tooth method if there is a big difference over a larger area...its cheaper. One point about the dog tooth method...I usually use a bit of batton cut to size rather than a bit of tile. Sometimes the edge of the cut tile can mark the front of the tiles that you are sliding over.
a bit late, one of the bathrooms dads blackberry 060.jpgdads blackberry 058.jpgdads blackberry 072.jpgdads blackberry 083.jpgdads blackberry 085.jpgdads blackberry 084.jpgdads blackberry 123.jpgdads blackberry 056.jpg
Save another half hour with the dog tooth method by cutting your template 2mm shallower than the depth of the mosaic and then beat your border straight into the one bed. Gives a flusher finish as well as not being as messy and fiddly.
It's a pain having to dig the adhesive out from between the mosaics but it gives a damn good bond!!
AliGage,
Stef,
AliGage,
Stef,
