Currently reading:
marking your cuts
Discuss marking your cuts in the Canada Tile Advice area at TilersForums.com.
DHTiling
what do you mean rake Dave? I mark tile once, then take back to cutter then cut, i don't double mark when doing a cut next to a wall that i have tiled, if i need to double mark then i know I've messed up the previous wall
Some old houses , the walls could be megga out of plumb , so point to point marking is required , not all jobs are 100 % plumb and square , welcome to the real world of tiling.
charlie1
no need for the welcome, been here for a while. If the wall is out of plumb then i will always look for a solution to correct this, especially if tiling an external mitre then its a must! Having said that, if the only solution is to tile then mark tile then flip and mark ( point to point)
DHTiling
120 yr old house , quadrant shower in one corner of bathroom , no other tiling , walls out of plumb by 6 inches but flat , how do you plumb shower walls. ?
Reply to marking your cuts in the Canada Tile Advice area at TilersForums.com
  • Sticky
  • Suggestion
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread - which has more than 500,000 views, and thousands of posts to scroll through - we thought it would...
Hello, after watching so many instructional videos and planing, I just can't understand how to tile a simple drywall construction in our bathroom. I got some good advice here so I hope you guys...
  • Sticky
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
