Brad
Hi all......have a question regarding the laying of marble mosaics.....they are the small rectangular brick-block pattern, dark brown coloured, about 10mm thick. I know that adhesive and grout have the tendency to bleed thru marble if not sealed properly.......i'm using bal white rapid to tile the floor......could i use this for the mosaics on the wall or will the white bleed thru??.....also, is it ok to seal after grouting, or will the grout bleed thru if not sealed before???.......
thanks!!
thanks!!
