Currently reading:
Making a shower area waterproof
Discuss Making a shower area waterproof in the UK Tiling Forum area at TilersForums.com.
sim01
Hi, I am about to fit and tile a new shower area. Web comments on how to ensure it is watertight seem to conflict with each other and I'm now more confused so I'd be grateful for some expert advice.
The three walls of the shower area are:
1. new stud
2. old lathe and plaster
3. internal brick supporting wall - back to the brick because the plaster was blown.
I am concerned about the brick wall (the others I intend to fix water resistent board to tile onto). Do I need to render the wall before applying the board or can I fix the board to the bricks ? Do I also need to tank the walls in either case? Thanks for your help.
david campbell
Hi Davy,
I am thinking of using something cement based like aquapanel or maybe wedi tileboard. On the brick wall can I just attach the board to the bricks using dabs of adhesive? One other question occurs to me - the lathe and plaster wall is pretty sound - I assume it will be strong enough to tile!
20kg per m2 on the plastered wall is the recommended heaviest load it can carry:thumbsup:
diamondtiling
Hi Davy,
Aqua panal has to be mechanically fixed, it states on the board not to dot and dab, at least it does on the knauf aquapanal.
:thumbsup:
Reply to Making a shower area waterproof in the UK Tiling Forum area at TilersForums.com
  • Sticky
