Discuss Laying quartz Tiles in the Tile Adhesive / Grout Advice area at TilersForums.com.
Tile Shop
Yes that is correct, but if you are a novice, to start with, I would be inclined to measure out the adhesive and additive into smaller batches so you can concentrate on getting it right.
Main thing is to keep the correct ratio between the powder and the liquid so have some scales on hand along with a measuring jug. The last thing you want is to mix up a whole bag, then lay 5 tiles, adjust them to your liking, to find it is beginning to set in the bucket.
Take your time and get it right, because the combination of tiles and adhesive you have is an expensive one to get wrong....... no pressure :)
Tile Shop
With the powder that is. Zero water. Have a look on mapeis website and download the tds for both the keraquick and the latex plus. It'll give you the correct amounts on there.
From memory, every application i've seen for the latex plus is that its a substitute for water. Not sure if you can use half and half. What do the quartz suppliers recommend?
Some will say "latex based adhesive" and others will say "low water content adhesive". Going for the 100% latex is by far the safest for either.
P
Planespotter
Yes I think your right 100% latex for me, on the can of latex it says 1.5kg of latex plus with 5kg of powder,i'll let you know how I get on ,starting monday ,if I mess up you can come and help ,your close enough (hehehe) only joking
kind regards
We have an excellent fitter in the Bedford area if you get into difficulties.
But definitely as advised, mix small batches at a time, this would never be classed as a diy adhesive.
You'll need to achieve as near to a full bed as possible.
Trowel the floor in one direction only, left to right is easiest, then using the back edge of the trowel apply a skim of adhesive on the back of the tile. Make sure the back of the tile is dust free, even wipe the back with a lightly damp sponge first. (Not wet)
Place it in the adhesive and move it perpendicular to the direction of the troweled adhesive on the floor, at least the distance of the width of each individual rib of adhesive. This will collapse the ribs and help form a full bed.
Starting off I wouldn't trowel any more adhesive on the floor greater than enough for two tiles, and take it from there.
Good luck.
P
Planespotter
It's unlikely to be enough, you can't cut corners with these materials. It must be done correctly.
Quartz can be troublesome.
Ok thank you for your advice, A really great forum with lots of advice,i'll be back with some questions about glitter grout,my wifes bought 2 tubs of the stuff but I cant find any info on the company on these forums ,the company is called Staffordshire silicones
P
Planespotter
Finally finished,im going to do epoxy glitter grout today,my kids hate it but at least the dogs happy
P
Planespotter
Ive now completed tiling my kitchen ,may I just say a big thank you to everyone who's offered advice,it was invaluable and I would not have attempted it without it.
Also to Miss tiler who helped me with the epoxy glitter grout,I was very apprehensive at first but with information and advice from Sharon I managed it
Thank you all
I
Italy
grouted with epoxy is a state secret?
of what use is forum?
I, every evening I see trends that have nothing to do with my work, just missing the trend, "what kind of uses at work underpants", then I read everything.
when there is an interesting trend, which serves many tilers, (myself included), what happens?
private conversation ......
as Italians in the 70s, when they came to work in the UK and did not want to see how you got the job done.
Reply to Laying quartz Tiles in the Tile Adhesive / Grout Advice area at TilersForums.com
  • Question
Hi, I‘ve just finished tiling the majority of my garden path. Base is concrete, and tiles are porcelain. I’ve just got to the end of my bag of Mapei flexible rapid set tile adhesive (powdered)...
  • Question
The saga of my hollow floor 50sqm continues. All tiles now lifted but there is adhesive around the edges of most tiles (800x800) and a small amount on the back. Whats the best method of cleaning...
  • Question
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
  • Question
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
  • Question
A little help guys. I've been asked to price 71sqm of limestone flooring. My issue is this, The property unfortunately flooded throughout. Now although I'm told it's all dry now I'm reluctant...
