Joined because saw lots of good advice here.
Becks
Hi Guys,
Happened across your forum because like many others I have the problem of new grey slate effect porcelain tiles now covered with white marks and some sort of residue after the kitchen fitters left. :incazzato:I assume its a mix of emulsion paint and plaster dust but it is incredibly stubborn. No amount of scrubbing and scouring with ordinary household cleaners has helped. There is no sealant on the tiles, informed we didn't need any. So reading through previous posts I see a lot of good advice but is the general consensus that LTP Grimex would be best or the aqua mix phosphoric acid substitute? also if I spot clean the specific areas will it leave them looking different than the rest of the tiles? should I clean the entire floor ? Not sure what the tiles are called but they came from B & Q are dark grey and have a matt finish.
Would really value your opinions
Becks
Hi and welcome.....if there a glazed tile then can't see why they would need any sealer, is there a main contractor to talk to about the mess.
hi becks are they the porcelthin ones from b and q, if so they claim on the website only not the packagaing that they do not need sealed but would benefit from it to stop stains!!! make of that what you wish ...i can also advise if it is these tiles to seal them as they will stain with grout application
some of the matt finish porcelain tiles may need sealed check there website more info on there than the boxes
Whichever you use to clean the mess always do it in a unobtrusive test area first, and I'd not spot mark it always do a whole tile.
Welcome!
Becks,
Time's Ran Out,
Becks,
Time's Ran Out,
