Discuss How best to Tile a room? in the DIY Tiling Forum area at TilersForums.com.
mp3wizard
Morning all, makes a change for me not to be centre of an argument. I understand that it is the done thing to centralise it usually, but there 800mm tiles I'd rather see a full a tile as possible for majority of room, rather than make 2 cuts, I know there will be some furniture on that side but it's not all about hiding it, I personally don't see it being terrible, needs to be cut somewhere, that would mean having a cut by bifolds and entrance, I'd rather just have a cut by bifolds. My bathroom is extremely small so again being able to see huge tiles going under bath with fewer visible cuts would be my preference, and same for kitchen, as cabinets will be sat over perimeter.
is it because Ive advised it ? ,
Haha no Craig, why the hell would you think that! Haha the way I look at a job is just different to yours, like you would look at a plastering job different to me, that's all, it's nothing sinister. Haha
Time's Ran Out
I think you're taking things to an extreme there John in the way you're deciding to translate previous posts.
If the guy is in, what he considers to be his home for life, and he wants to see 3 full tiles throw the main entrance to his kitchen, but it leave a smaller cut to one side, which will be hidden amongst fixtures and fittings, why the hell not?
How far have you got to stand back to see a room
4-5m wide and be able to take it in within your peripheral vision?
Saying a space has to be centred without exception is just short sighted and not what we're paid to do.
We're there to give the client what he wants and the best possible finish.
When have you walked off a job because you weren't allowed to centre a room? Haha
Not sure if you even read my post with this reply!
John Benton
1,138
Leeds
Who's
You will have to make 2 cuts, if you come square off the bi-fold doors
Tile Shop
I'm not even going to pretend that my advise is up there with other time served Tilers in terms of setting out as I haven't had to do it often. But, if I had centred my kitchen floor tiling to the whole room, I would have had a 2 inch slither in front of my units on one side and almost a full tile on the other. Would have looked poo. So I centred it from the main focal point and the largest visible area.
Now the only visible "slither" is 4 inches wide in front of a stepped door way right opposite another door so you do see it when you enter the room from one end. There are also some short cuts at one end of the room that you can't see because of a fridge and a dining table. But its the lesser of two evils. Better than having a 2 metre long, 50mm wide turd in the kitchen. Nothing is going to get moved around in the near future, and my missus is happy with it.
Ok John I'll apologise,I may have focused on your last sentence more than the whole post.
Bit of a knee jerk reaction on my part.
My intention was to say that, the fact that furniture will be covering that side of the room isn't really being considered as a setting out factor, it's being considered more as a compromise to give the overall desired effect.
I'll try not to respond in haste cos I'm walking out the door in future. :)
Bill
I don't centre any floor. I just tile it how it will look best for the tiles and room. If that means starting with a full tile from the rooms focal point then so be it, the same can be said if I centre it. Unless you are tiling a repetitive area then each job should be set out on its own merits.
Now that is the best advice on this subject and I expect a trusted advisor badge forthwith.
I
Italy
I can give you mine if you want...:) I do not need, I'm already over the badge green ;)
Reply to How best to Tile a room? in the DIY Tiling Forum area at TilersForums.com
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
