Discuss Help! SLC fail - Self levelling compound failed Pro 50 in the Australia Tiling Forum area at TilersForums.com.
Budha7
Hi All
I have an issue which I would like to hear your thoughts on.
I have had a floor fail on me, and need to get to the bottom of what has happened.
The floor is timber, screwed to joists and checked for deflection.
Then overlaid with 10mm backer board, screwed to floor. No primer.
UFH loose wire system laid and covered with Norcros Pro 50 leveller.
Ardex AF200 adhesive for holding Ditra mat.
Norcros Rapid flex ontop for tiles.
The tiles are all moving, and on cutting a tile out, it is the SLC which has failed.
It has big cracks in it, which are curled at the ends. Raised around 5mm on the edges.
The only way I can describe it is if you can imagine a dried out lake bed?
The room never got above 15c when i was working there, the windows were closed and the customer was on holiday, so all heating was off and no hot water was being used (warm pipes).
I have photos and will try to upload, but i am unsure how at the moment, bear with me.
Can somebody please help!!
Thanks for the great forum!
Budha7
Reply to Help! SLC fail - Self levelling compound failed Pro 50 in the Australia Tiling Forum area at TilersForums.com
