Dural Durabase Ci++ Uncoupling Membrane Matting
Dan
Admin
Staff member
DURAL decoupling mat DURABASE CI++
The quick multi-purpose decoupling mat with shear-stop action
Particularly safe, extremely fast, noticeable cost saving
  • Construction optimized 3-layer structure
  • Stress alleviating and crack-bridging
  • Improves footfall sound insulation
  • Saves time and money
Construction optimised 3-layer structure
Mesh fabric
  • Higher bending strength of the flooring construction – stable flooring.
  • Better adhesive bonding between the mat and the thin-bed mortar.
  • No roll-off effect – the tile adhesive does not roll off when it is spread across the dimpled structure.
  • Highly resistant to mechanical loading.
Geometry of the dimples
  • The optimised shape of the dimples results in a significant reduction in the amount of adhesive required.
  • Improved equalization of water vapour pressure.
  • Optimised adhesion.
Fleece fabric with active fibres
  • The active-fibre fleece increases the adhesion surface area and guarantees optimal adhesive bonding between the mat and the subsurface.
  • The reinforced material of the fleece fabric minimises shear stresses.
Applications
Freshly-laid mineral subfloors
  • Cement screed
  • Calcium sulphate screed
  • Concrete
Subfloors subject to plastic deformation
  • Old synthetic flooring
  • Mastic asphalt screed
System floors
  • Double floors
  • Raised floors
Outdoor flooring
  • Balconies
  • Patios
  • Verandas
Problematic subfloors
  • Cracked subfloors
  • Mixed-material subfloors
  • Wooden subfloors
  • Heating screed
  • Dry screed
  • Metal subfloors
Large-format tiles
  • e.g. > 50 x 50 cm sufficiently thick and fracture resistant. No thin tiles – as these could break)
Advantages for tile fitters and floor layers
  • Bridges cracks and alleviates stress
  • Functions as waterproofing in indoor applications
  • Faster laying, thanks to easier spreading of the adhesive
  • Less adhesive is required, thanks to the optimized shape of the dimples
  • Easy to handle and unroll – CI++ moulds itself to the floor (is not stiff)
  • Improved transfer of loads, in line with DIN 1055-3
Dan,
Dan,
Dan,
Dan,
