Discuss drytreat stain-proof in the UK Tiling Forum area at TilersForums.com.
peckers
I have used the drytreat products not all of them. They seem to be very good, i tested it against ltp product on the same piece of tile applying it on each half being careful not to go over the edges and it looks like the dry treat is absorbed further into the stone. Also after just only one coat if you put water on it, it is as if the water is being forced apart and you get lots of little droplets(like when you bang the bubble in your level) and they seem to roll arounfd on the tile.
Good stuff in my oppinion but it is potent need to open all windows and doors! :thumbsup:
DHTiling
I have recently received a sample of drytreat with a view to possible use in sealing my limestone flooring project and i would be interested in comments from all who have had experience with this product.
I have done some stain tests and my findings are that it provides better stain protection than ltp mattestone.
Can you run us through these tests..please.
dgman
dave,i have divided a sample tile into two halves via a strip of tape,on one half i applied four coats of ltp mattestone sealant and on the other half applied four coats of drytreat stain-proof.the application process followed the guides by each manufacturer.
the test,
after allowing 24 hours to cure i poured half a teaspoon of neat blackcurrant cordial onto both treated patches and set my timer for five minutes.when time was up each sample was blotted up with kitchen roll.
the result
ltp mattestone,visible blackcurrant stain on tile.
drytreat stain-proof,no blackcurrant stain on tile.
Tenchman
Hi DGman i have been using Drytreat for over a year running tests against the other known sealers in my case as most of my work is on listed buildings i need to be sure otherwise big fine or worse.
I found it was easier to use as the cleaning off is simple i haven't had problems with patches getting tacky as has happened with other sealers and it allows the tiles to breathe which as most of my work is over lime screed is very important.
I tested it using a tank the middle of the tank had a piece of granite fitted this was sealed with stain-proof and filled with water the lower half had air pumped in under pressure, no water dripped through either with a granite bed or local red sandstone however the pumped air went through and bubbled up into the water.
I'm happy it does what it says and have used it to eradicate efflorescence and am in the process of getting the process validated with the likes of Historic Scotland and other heritage organisations.
Plus if an approved applicator puts it down it gets a 15 years warranty.
Cheers Steve
Tenchman
Hi DG, I have used the stain-proof & meta creme the latter you leave on longer but it goes deeper = good stuff tad expensive but if you want to be able to just mop etc without re-sealing and the upkeep of polishing constantly then it is a good choice.
It was originally for use in concrete upkeep in Oz and stopped spalling thats how i know about it.
But it has only been available here for relatively short time, i'm going to switch to it as it stops a lot of the headaches for me = we restore victorian floors =often major works architectural improvements etc and then the damn seal gets flaky or tacky etc etc so thousands of pounds of work is thrown to one side on the basis of a cosmetic application.
Don't get that grief with dry-treat it goes on quickly you can walk on it very soon after and it works quicker it even seals granite & most porcelain even did a corian top.
Cheers Steve
strummerman
are you tryin to sell sumit
dgman
dave,as administrator i am sure that you have access to the private messages on this forum.please take a look at my messages and you will see that i have had contact with a tiler who will be coming to my house to survey and price the job,after he has been i will ask him to contact you to prove that i am not a trader ,pedler or middle man for any company at all.
regards
dgman.
Cerbera450
You also tested it becuase thats what i had on my van cheeky chops!!:lol:
I have used both the stain stop and the meta creme, both are very good products. I have also used the Tikko impregnator which i superbe. Dry treat and Tikko products are easily the best on the market.
Reply to drytreat stain-proof in the UK Tiling Forum area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
  • Question
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
  • Sticky
  • Question
