Clipper TT200 for cutting pavers
We are in the process of planning to lay concrete 400x400x40mm pavers and will need to cut quite a few of them (approx 40). Hiring a saw works out to be quite expensive (have 2nd project a bit later on) so am looking at options to purchase a DIY tile (paver?) cutter and have come across the Clipper TT200 which looks like it may do the job. The Clipper spec mentions a max cutting depth of 40mm. Will the Clipper be suitable to cut the above concrete pavers - will the included blade be suitable or should this be upgraded to a blade specific for concrete.
The alternative tile cutter we are looking at is the Ryobi 100mm Wet \ Dry Tile Saw which should do the job but will require 2 passes.
Any comments much appreciated.
Tags Tags
cutting
PeterB_In_Brisbane,
PeterB_In_Brisbane,
