Discuss Can I use Travertine for a Hearth?? in the UK Tiling Forum area at TilersForums.com.
Stan001
If you mean hearth surround (the verticals) then ok, if you mean the actual hearth base then i personally wouldn’t. Although it’s ok for heat trav is too soft and the edges will chip and break when someone stands on it. A granite base can be cut for about £150 and laid in about 45 minutes – will last forever and look great forever.
(i may have misread your original posting but i think you know what i mean – would be great to see pictures afterwards, I’m always looking for fire base and surround ideas)
diamondtiling
Travertine is laid on floors all the time and people walk all over it, why would the edges crack and chip Stan? If laid with 100% coverage and sealed and grouted it is perfectly ok for the fire hearth.
:thumbsup:
Reply to Can I use Travertine for a Hearth?? in the UK Tiling Forum area at TilersForums.com
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm...
  • Sticky
