Without knowing the surface and thickness you are trying to achieve, it is hard to give an exact answer, but assuming that the surface is solid and reasonably flat, I would dot & dab a tile backer board, with securing screws inserted the following day for extra security. If the surface is a poor, scratch up with sand/cement render first. The render will be dry enough to fix the boards after two days.
