Discuss Best tool for commercial tile removal in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com.
dchtilingnorthwest
Hi all
What tool does everyone use to remove grout from existing floor tiles in order to remove and replace individual tiles?
Getting a few of these jobs and the grinder followed with the vac is too fiddly, slow and kicking out too much dust....
Cheers
Q
Qwerty
A Fein or other variable speed multi cutter is best for domestic situations but IMO a variable speed grinder with a decent blade, steady hand and vacuum is best for large areas.
dchtilingnorthwest
Ive used a hilti wall chaser before which we hired. Just trying to eliminate the dust from using the grinder and vac.
Bond
518
Highland
If your thinking of using a multi cutter, check out the range of blades available for grout and adhesive removal @ smart-toolgroup.com.
Sorry for late reply.
A lot of us use this, very effective!
HERZO Expert 115mm/125mm Universal Surface Grinding Dust Shroud For Angle Grinder https://www.amazon.co.uk/dp/B01G3OLCG2/ref=cm_sw_r_cp_api_kwE2zbST8HP2C
Reply to Best tool for commercial tile removal in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com
