Discuss Bath trim and resealing advice please . in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi folks .Nees some advice .I had a bit of water cone through the kitchen ceiling the other night .Realised the trim around bath needs replaced but its a quarter round trim and seems to go up behind the bottom tiles.Is there a way to reseal without removing the bottom tiles .
take a photo so we can give a better bit of advice, please.
Does anyone remember when we put trim around the bath
I think I was 20
I think I was 20
With Bal Wall and self spacing tiles.
Sorry for the silly question, but do you just not use trim any more? Or do you use something else?
Thanks.
When baths were solid, bath trim sets made of ceramic, and were used to hide the gap between the bath and wall. They had internal mitres and coved ends. The top and bottom edges were siliconed for extra waterproofing.
Then they came up with plastic bath seal which was fixed with adhesive to the wall and sat on the bath ( which often moved) and this had a flexible edge seal. These often kicked out the first row of tiles. However over time the baths moved considerably and moisture would get under. The only way to remove this bath sealer strip was to take the first row of tiles off.
A bath today should have a wall mounted baton to take the bath frame, legs correctly fixed to a stable floor, and a good bead of silicone before and after tiling.
Job done!
Job done!
I still have some of that from years gone by John
Reply to Bath trim and resealing advice please . in the Canada area at TilersForums.com
