- Reaction score
- 177
I've done quite a bit of research on this gypsum based screed. The results are quite alarming from a lot of experienced tillers.
today I fitted (or started to)200m sq of ditra using TM anhyfix adhesive. it goes down ok but then when you push the mat into the ditra all seems good.... until you come cack to it in an hour. all it does is leace the imprint of the mesh backing on the anhyfix tile adhesive. I literally didn't need to clean the ditra!
Anyway I phoned schluter helpline and they said to use primer 3;1 then again prime 1;1 when dry and use ardex cement based adhesive to get the right adhesion to both surfaces. This would have cost me in excess of 20k to fix if id not spotted the problem.
hope this helps some guys in the future regarding anhydrite screeds.
