Advice Needed Please
Walshy
Hi,
I have taken up the tiles in a bathroom floor and underneath seems to be ditra matting fixed with tile adhesive directly to floor boards.
I can pull the ditra away but it leaves some of the felt backing and the vast majority of the adhesive on the floorboards.
What would you advise as to the best way out of this issue. I want to install underfloor heating and tiles once the underlying floor is suitably prepared.
Trying to get the old adhesive off the floor will be very time consuming is there a better way to proceed?
Should I just rip out the floorboards and lay a Ply or floorboard replacement?
Thanks for any help in advance
You have to decide whether spending your time chisling adhesive off could be better spent taking up and replacing the whole floor...10mm insulation boards glued and screwed before ufh and a thin crackmat would normally cover most situations....gotta get that floor clean or replace before hand though 🙂
I'm guessing it's a relatively small area.
The polyethylene fleece left behind will bond well enough to fresh adhesive (if it's clean - not dusty).
I would bond insulation boards with a decent s1 adhesive and also fasteners into the floor.
Then do your thing...!
That lot from Middlesbrough....or is it jordies... "danny know wat I'm ganee do" etc etc : ) long story just explaining the 'uncanny '
Thanks for the replys, Would you bond the isulation boards on top of the old adhesive /ditra backing or does that need to be removed first Impish? If so does it all need to be primed first? (there are a few small area where there is little or no felt backing). Your right it is a small floor (6m2). If I decide to replace the whole floor would 18mm ply be the recomended way to go and would that then need some tile backer boards on top or be good to go as it is?
Apologies for the question bombardment
If you're happy that the old adhesive is stuck fast, then it's a certainty the ditra underlayment will be also, so just bond straight onto it. If it's dusty, vac it but I wouldn't prime it. It's polyethylene (I seem to recall) and the bond is brilliant.
Ok, thanks again. I'll remove the rest of the ditra today and make a decision from there. If I do decide to replace the floor would an 18mm ply replacement then need backer boards also or be good to go on its own?
Walshy,
Walshy,
Walshy,
Walshy,
