Discuss 1st Job Pics in the UK Tiling Forum area at TilersForums.com.
C
Caledonian Tiling
Hi All,
Here are a couple of pics from my 1st customers job ever, as you will
see from my new member post, the walls around the workboard were
sh*t excuse the language, with about 1 1/2 inch "craters" in certain areas
with plaster board running up to an old runner where a door in the wall used to be, then dipped straight down to the brick back up to the cement level covering the brick then the large gaping holes around the sockets....lucky me...
I worked my *** off and stressed loads to level out trying to use filler at 1st
before finally bonding out with plaster... i learned loads but my god it was a tough experiance...
Cheers.
C
CON5933
Hi All,
Cheers.
You'll be glad the 1st ones out ofthe way, well done.
A similar problem with the walls..... I 'dot & dab' when ever possible...
[DLMURL]http://i6.photobucket.com/albums/y250/ifconnn/PICT0115.jpg[/DLMURL]
broken link removed
For this I earned the grand sum of 2 bacon butties and all the tea I could drink...:wink_smile:
L
Leatherface
I'm lucky - bad walls - no can do. I will spot & dab plasterboard at a push - can't be arsed though. Tell them to get walls sorted. Always seem to have enough on to knock back the bad ones
C
Caledonian Tiling
Guys,
Cheers comments good/bad or indifferent all appreciated, one thing i do and will
continue to try and aim for is to get it done right and the tips/feedback from you
pro"s helps enormously...............
Caledonian.
L
Leatherface
Forget the rest - try to be the best.
REPUTATION - this counts for a lot - keep it & the work will come to you.
Loose it & loose the work.
Good luck mate
C
Chrisfaefrance
Looks good to me Caledonian. Nice work. You to Con.....nice "before" and "after" pics. What a difference !
V
vince1
nice work there that bit about the bacon butties made me have a little laugh and how fat you would be if you done the full house lol lol lol
Reply to 1st Job Pics in the UK Tiling Forum area at TilersForums.com
