Discuss Opinions , 20mm screed removal in the General Off-topic Chat (nothing tile) area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
I've been to look at a screed part of which is 20mm higher than the rest . Easy option screed up , but that's going to take £700 of levelling .
So options I see .
Grind it , score/cut into sections with disc cutter and kango or take that piece of screed right out .
Any bright ideas and options welcome
Italy
Q
Qwerty
Ive only ever ground down high spots but at the size I'm imagining yours is I reckon your plan is probably better
Albert
So options I see .
How big is the area you need to remove? Can you not fix 20mm backer board
Removal area about 1.5 x 3.5 . Thick backer board and floating level is an option but its then the knock on effect to the kitchen, maybe I should of mentioned that.
Albert
You could hire a floor chasing machine set it at the hight you
need and run it back and forth then finish with a kango,
or hammer and chisel
Albert's idea would work but is very very labour intensive.
Grinding with dust control would be physically easier.
Whatever you do it's going to be an expensive soul destroying pig of a job.
Personally, I'd offer suggestions to the customer on how it could be done, and offer to come back when it is done!
I was thinking . "You best get the builder back to sort his shoddy work out , I will also leave this yellow stick which has a bubble in it. "
Reply to Opinions , 20mm screed removal in the General Off-topic Chat (nothing tile) area at TilersForums.com
Lowpaul22
