Discuss Advise on replacing bathroom floor in the Australia Tiling Forum area at TilersForums.com.
Boggs
1,118
Uk
Hardie backer and metal studs, Good luck to whoever gets to rip that out in a few years!
Been there, complete nightmare!!!
Waluigi
Might be a consideration to use new bare plasterboard on the metal studs. This increases your weight limit.
Boggs, I just had a think about that, what a nightmare as you can’t tear the stuff down.
tony Dimartino
Is it the right way about doing it? Which backing board is best there are so many to choose?
Boggs
1,118
Uk
Nope, 20sqm bathroom, porcelain tiles on 12mm Hardie screwed to metal stud work.
Could not get the tiles off the Hardie or the board off the studs. Took 2 of us 1.5 days to strip out!
Also the issue with the dust created by breaking it apart, not good.
Hardie backer has its place but not on metal studs.
Boggs
1,118
Uk
I would remove existing skimmed plasterboard and replace with moisture resistant plasterboard, just tank the wet areas.
With tanking you should still be looking at 32kg sqm, so should be fine for 600 x 300 porcelain and adhesive.
P
Perfect Tiling
I'd agree with the above. put on new plasterboard and tank it. I doesn't need to be moisture resistant...not if your tanking it anyway. Also, some shower walls are on an external wall which requires duplex (foil backed) plasterboard and you don't get foil backed moisture check plasterboard (not up here anyway). When I'm doing floors I use a piece of stainless steel quadrant trim on the edge under the door...I leave about 6mm protruding for the carpet to be tucked under. It gives a nice slim rounded edge.....no stubbed toes!
Reply to Advise on replacing bathroom floor in the Australia Tiling Forum area at TilersForums.com
