Wet shimming backerboard
not something i recall being talked about before on here? Does anyone wet shim studs etc when boarding a wall if there’s unevenness, a stud set back from the rest etc?
If you are boarding onto studs with backerboard and say a stud is bent 7mm out of plumb on one corner you apply a bed of adhesive on the stud where needed and put the board up get it level then screw up fully once the adhesive has set.
Understood your question but not the term.
I’d pack out an overboarded wall with adhesive where necessary and mechanically fix through to the substrate, but if it’s just a stud frame wall and no boards on, then I’d fix packers on the studs to level them through.
With the studs being raw timber that is still moving I think
no matter what kind of adhesive is used eventually it will fail
and leave a void, might be better to use packers
The one I’m doing just now, the original framing was so out and twisted that it was quicker to take it all apart and rebuild it so that packers weren’t needed. Sometimes better to take a step back to save time later.
A plasterer watched me using packers and adding bits of timber to crap studs once. He told me his method is to just screw boards on to the crap timber and then dot and dab 9 1/2mm board on to that to get it bang on. Not something I've done before but it made sense, it's not going anywhere and can imagine it would be super fast.
Thoughts?
Unfortunately it’s where we are at in the construction industry for a long time now.
Each trade has issues with the one before and lots have the it will do attitude. You have to throw it back to those in charge of standards or get on and overcome.
How often do you here - a good tiler would get over that - so check first, price it right, and if you want it do it.
Flintstone,
Dumbo,
Flintstone,
Dumbo,
