Discuss Fixing a single tile in the Tile Adhesive / Grout Advice area at TilersForums.com.
Swindiff
I need to fix a single tile as a sink splashback in a cloakroom. The tile is a 600mm x 300mm porcelain tile. It's the tiles that were used for the flooring. I don't have any tile adhesive but I do have some tubes of gripfill and dow 785 bacteria resistant silicone. As this is just a single tile is there any reason why I should not use gripfil or silicone rather than buying some tile adhesive for a single tile. The wall is plaster board. Cheers
Q
Qwerty
Yes, because it is the incorrect method fixing tiles and could fail. If you have no adhesive just buy some
Brian the Tile
973
north wales
If it was a few i would say no ,but for one tile i would say either will do it
GAZ5518
558
EPSOM
Whilst not the correct way to fix a tile .. Gripfill will do the job on this occasion.. It will stick like Sh## to a Blanket... :rolleyes:
Reply to Fixing a single tile in the Tile Adhesive / Grout Advice area at TilersForums.com
Hi, I‘ve just finished tiling the majority of my garden path. Base is concrete, and tiles are...
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
