Currently reading:
Sigma 3e3m
Discuss Sigma 3e3m in the Tiling Tools area at TilersForums.com.
Stef
Back onto the job today & someone has moved my cutter, went to use it & the handle doesn't glide like it normally does, was sticking when I pushed or pulled it.
Sprayed it with silicone spray, it's improved but still not the same, not sure if it's been damaged in any way.
Not a happy camper.
Inside the handle looks like this.
Anyone any ideas.
L
LM
Not a happy camper.
Anyone any ideas.
View attachment 82414 View attachment 82417 View attachment 82418
Stef two things to check, there's a nut and bolt on the handle above where the handle glides over the bar, if it's tightens too much it clamps the handle on the rail and stops a clean glide, another problem I find is a build up of addy dust inside the handle sides and if you pop the handle off and give it a once over with a thin wire brush this removes it. It's hard to see in your picks but it looks like there might be a bit of residue inside the handle
Italy
is silicone spray.
absorb dirt.
wd 40 is better
Stef
I gave the handle a clean today & cleaned the bar.
The nut & bolt on the handle are quite slack but it feels as though the handles too tight on the bar.
I was convinced that the boys had bent the bar but there is no way that you could bend the bar on the cutter.
Will give the handle a thorough clean & try again on Monday.
Reply to Sigma 3e3m in the Tiling Tools area at TilersForums.com
You're browsing the Tiling Tools category on TilersForums.com. Find the correct trowels to use with which type of tiling. Find advice on lash clips and levelling systems and more.
