Discuss Rain On Tile in the Canada Tile Advice area at TilersForums.com.
Italy
Adhesive was already hard. when rained?.
if yes. let it dry. before of grouting.
I use. leaf blower. help a lot.
E
Elise shifman
It's all water resistant so I wouldn't worry, just let it all dry off fully before grouting. As Long as it wasn't pouring down before it was set
So water won't get trapped under the tile when it is grouted? My concern is that it gets trapped under the tile, it gets grouted, than if we get a freeze in the winter it could crack and buckle.
SJPurdy
There should be no gaps under the tile for water to get trapped in. The adhesive bed will have been rewet (like it was when mixed and used to fix the tiles) and it will again in the future as the grout will probably be water resistant but not water proof. I am assuming an appropriate outdoor cement based adhesive was used to fix the tiles to the substrate, then this should cope with the freeze thaw cycle providing it is a solid bed and that appropriate stress relieving movement joints have been incorporated (if it is a large enough area to warrant them).
Reply to Rain On Tile in the Canada Tile Advice area at TilersForums.com
  • Question
Hi, I‘ve just finished tiling the majority of my garden path. Base is concrete, and tiles are porcelain. I’ve just got to the end of my bag of Mapei flexible rapid set tile adhesive (powdered)...
  • Question
  • Question
  • Question
