Currently reading:
Setting Out...again
Discuss Setting Out...again in the Australia Tiling Forum area at TilersForums.com.
macten
1,158
Nottingham
Large kitchen splashy, 2 windows (one really long) and probably going to be a metro like tile :mad:
From worktop to sills is about 11 - 11.5cm so when I was round there I explained common size for those types of tiles are 10x20s and showed why that would mean an aesthetic compromise somewhere and to try and find a tile 7.5 or 12.5 high she liked if possible. It looks like customer's heart is set on a 10x20 she has found.
Now my question is would you (like I have in the past) raised the sills as much as the window frame will allow to make the slither cut as big as it can possibly be (still going to be a thin cut though) or would you even consider less than full tile off the worktop or maybe a combination of both. Can't imagine anything less than full tile off worktop - especially metros, would look worse.
Bisel Sage
Those are the tiles she likes so my other question is does anyone know of a similar tile in a more suitable size?
macten
1,158
Nottingham
I'll certainly have a go with my hammer and bolster at the sill to see if it's feasible to lower it significantly - happy days if that's the case but if past experience is anything to go by they'll be little to be gained - usually beading straight on blockwork.
macten
1,158
Nottingham
If you plan to cut the front of the wooden cill off in the future and tile over, the heat from the sun will cause it to move/crack and need replacing. Always worth building up with plasterboard.
You should be able to reduce the height of the cill even if it's the case of taking a brick course out and rebuilding up - but as always there's a cost involved in perfection!
True John, but I believe pdc's suggestion was on the basis of there being a wooden sill in place and so didn't require tiling - not tile over a wooden sill.
I've let the customer know about compromise if she wants that size tile. I know for a fact she won't go down the extra expense of me taking a course of bricks out and to be honest I wouldn't want to do that - surely I'd also have to remove the row of outer skin bricks the windows are sat on?
From my emails with her I think she got the impression that small cuts would be a nightmare for me to cut and fix and I've explained that it's no hassle for me but just won't look as nice. Up to her at the end of the day
macten
1,158
Nottingham
I've got the same dilemma in my own kitchen, so far the best compromise I've come up with to the window cill (haven't even thought about rest of the room) is to start off the worktop with a tile cut exactly in half (therefore not too wastey as able to use both halves for same thing) which will leave me with a full tile at cill edge.
I've done exactly that once before and it looked really good - obviously not ideal but was definitely the best compromise. Just don't think it would look good doing that with metros (being bevel edged and all)
P
p4ulo
True @macten , I've got XL metro style flat faced tiles to do it with so hopefully it will work....
Don't see why it wouldn't work with the metros with bevel edge, maybe do a trial with her and the different options and see where she lands.....?
macten
1,158
Nottingham
Raise the cill imho. Usually plenty of room , especially if you can see the back edge of the window board.
Diggy
There's enough frame on show to put a piece of plasterboard on - so can only raise it about 13mm - this is still going to leave a slithery cut.
Time's Ran Out
No, he (pdc) suggested cutting the front of the wooden cill off!
With the cavity it doesn't affect the outer course of bricks and although every job is unique it's something I've often done at no extra charge to overcome the exact issue you are having.
You are possibly looking at half an hours work, some fast set adhesive and a plasterboard. This will provide the perfect finish, a happy customer, and a problem solved - and be as quick as trying to cut the slithers you will have otherwise.
macten
1,158
Nottingham
Well I'm nearly finished this job and managed to build up enough to get it looking alright.
Reply to Setting Out...again in the Australia Tiling Forum area at TilersForums.com
