Tarmac Trueflow B
The only one ive done the house owner sanded it and primed it.
He used a 9" grinder with a wire brush kinda attachment thingie , vac'ed it and primed it,100m2 of it, the bloke did a top job , took him all weekend.
We used tilemaster primer and anylfix addy , as far as i know its still fine and dandy , im sure he would tell me as well being a detective in the oldbill 😉
Oops! Sorry! No offence intended. Having a sense of humour bypass today as had a burst pipe this morning and expecting a structural survey for selling the house làter in the week.... We all have bad days I guess
Course we do mate, no worries, I figured u didn't know the sarcy Manc anyway! Haha
Sorry to hear bout burst pipe! Crappy business!
I prefer to ask technical questions on the forums at least you get a bit of banter back with your info, the normal reply I get is
"keraquick with latex should do it"
It is my technical opinion that unless there is a very good technical reason why not you should uses gypsum based or at least gypsum compatible adhesive on gypsum based screed. Adhesives based on ordinary Portland cement are not compatible and it does not matter how much primer you pout down this will alwàys present a risk.
There are very few technical reasons why you would not use gypsum adhesive other than perhaps over a liquid damp proof membrane.
One reason i've heard although will admit, not seen first hand, the gypsum addy's can crystalise over time if it comes into intermittent contact with water.
So you've laid a floor with it, used a water resistant grout, you mop it regularly, so it gets wet.....
The two instances i heard of, it failed under and around the grout joints.... also bare in mind, cement based grout in contact with gypsum adhesive? You said yourself the cement and gypsum don't mix.
But i'm not a scientist so on the other hand, the guys who make it must have all the bases covered.
Never once had an issue with supplying acryllic primer with cement adhesive, so for now i'll stick to what i know works.
I totally get what you are saying @Ajax123 I understand and I am pretty sure your knowledge about this subject is superior to mine, I can't say why I am not using a gypsum based adhesive......other than Mapei don't manufacture one and the last time I used a mineral one it has started to fail but that's my own fault for not using Ditra as a fail safe.
So it is as the Mapei spec at the moment
Abraided
Vacuumed
Primed
Primed
Primed again
Keraquick and latex stick Ditra down
Keraquick to stick tiles down
My supplier only stocks Mapei so going elsewhere is not something I want to do if I am being truthful.
Abraided
Vacuumed
Primed
Primed
Primed again
360m2 in Keraquick and latex plus!
U masochist! Haha
Tarmac Trueflow B
AD Ceramics,
Ajax123,
AD Ceramics,
Ajax123,
