H
hungover
Last year I tiled a bathroom with marble tiles. The client wanted a marble bath top. The suppliers took my template and returned with 4 strips. I siliconed them to the top of the bath and then sealed them with the water based sealant that the customer supplied (I did express concerns about using a waterbased sealant but the customer insisted). I then used dow corning sanitary to finish off.
6 Months later the client rang to tell me that when ever they showered they had a torrent of water in the room below.
On closer inspection it seemed that the silicone was failing, I guess because the waterbased stone sealant was allowing the tiles to soak up water. I applied a white spirit based sealant and resiliconed. Some months later the clients had the same problem.
This time I removed the marble from the top of the bath and discovered that the undersides of the marble were "slimy" and that that whilst my silicone was stuck fast to the bath it easily pealed off the underside of the marble.
I have now sealed all sides of the marble the whitespirit based sealant and glued the marble down with Dow and Plumbers Gold.
Although the WS sealant is better than the WB it still allows the tiles to adsorb water and I am concerned that I will be back there in a few months.
Can anyone recommend a truly water proof alternative?
Many thanks
Many thanks
