Discuss Mosaic Technique and Construction in the UK Tiling Forum area at TilersForums.com.
DHTiling
The method by which mosaics are made hasn't changed much since ancient times. Advancements in tools and materials have made the process easier, quicker, and the results more varied and visually appealing, but over all the process is the same.
There are few written records of early mosaic techniques. The most comprehensive information regarding the creation of mosaic art was written around 77 A.D. by Pliny the Elder, a roman officer and encyclopedic. In the 36th volume of his Natural History series Pliny describes the technique for the proper preparation of mosaic ground.
According to Pliny the preparation of mosaic ground began with a layer called the statumen. The statumen was a layer of tightly packed pebbles and rocks between three and five inches (8 to 12 cm) thick. On top of this layer was a ten inches (25 cm) of rough mortar called rudus. The rudus was comprised of three parts gravel and fragments of terracotta and one part lime. The rudus was to be covered with a layer of mortar called the nucleus which was also about three to five inches thick. The mortar used in the nucleus was made of three parts sand mixed with smashed tiles and bricks and one part lime. The mortar used in the nucleus was of a finer grade than that used in the rudus. The design was inscribed into the nucleus and the mosaic tiles were affixed to the top with a layer of mortar created from fine sand and lime. The lime was often colored so that the lime between the mosaic tiles would match the color of the mosaic surface.
The ideal ground as described by Pliny would have produces a thick, consistent, solid pavement. However, much of what we know about the creation of mosaic works comes from archeological evidence. Such evidence counteracts Pliny's description of how mosaic ground was laid. Often the statum and rudus were left out. Sometimes even the nucleus was abandoned and the tiles laid directly into the fine mortar on the floor. It is most likely that Pliny was giving an example of the best method of laying mosaic ground, not the most common. Because of mosaics popularity and the time consuming and expensive nature of the work it is logical to assume that mosaic artists sometimes sacrificed steps in producing the ground to speed completion and limit cost.
Today mosaic is often created in a frame to prevent tiles from slipping or breaking off the edges. This frame can be made from various materials such as wood, metal, concrete, or resign with an aluminum core depending on the size, shape, and intended purpose of the mosaic. Mosaic tiles can then be applied to a layer of cement, clay, or mortar. Often materials like chicken wire and welded steel grilles, like those used in constructions work are used to reinforce layers.
There are two common methods of laying mosaic tile. The first method is the direct method. The direct method is rather simple. The design is sketched into the mortar and the tiles are pressed directly into the mortar. A wooden board or level is then used to flatten out the tiles and create a smooth surface. Finally a layer of grout is spread over the tiles then wiped off, filling any spaces between the tiles. This method is optimal for small mosaics or mosaics involving a fewer, larger, tiles and curved surfaces such as domes. The obvious draw back of this method is that there is little room for mistake and repositioning tiles can be very difficult. The mosaic must also be finished very quickly before the ground dries and becomes useless.
The indirect method of laying mosaic involves laying the mosaic tiles upside down on a cloth or clay backing then applying the mortar and backing to the back of the tiles. Originally the design for the mosaic was drawn on a piece of cloth or flat of clay, the tiles were laid on the cloth or clay in the accordance to the design, and a layer of mortar was spread over the back of the tiles. Then the backing was applied to the tiles and the design was flipped over and grouted. Now artists have the benefit of being able to use plasticine to position the tiles on. The indirect method is optimal for large areas, wall applications, and compositions comprised of many small tiles. The draw back of the indirect method is the possibility of tiles shifting in the process. These tiles are nearly impossible to realign one they are applied to the base.
There are several techniques or systems for laying mosaic tesserae (tiles) that influence the final look of a mosaic piece. The three most prominent techniques are Opus tesselatum, Opus sectile, and Opus vermiculatum. Opus tesselatum used black and white cubed tesserae ranging in size from 3/16th to 1 1/8th inches (.5 to 3 cm) which were often placed in a geometric formation. Opus vermiculatum is more of a paving technique than a mosaic technique and uses larger slabs of marble called crustae to form geometric patterns, animal and floral motifs. Opus vermiculatum uses very small tesserae under 3/16th inch (.5 cm) cut to exacting shape and laid closely together to form outlined drawings and subtle shading within the mosaic design. There are other mosaic systems used for various applications. These are as follows:
Opus incertum: This technique uses irregularly shaped, small, smoothed, slabs of stone fitted together in a random fashion.
Opus lapili:
The earliest example of mosaic in which pebbles were used by binding them with compacted earth or a mixture of sand and lime.
Opus musivum:
The name given to wall mosaics which use only glass paste tesserae are used.
Opus quadratum:
Tesserae in the shape of a parallelepiped (three dimensional rectangle) arranged in horizontal rows to achieve a checkered effect.
Opus reticulatum: Tesserae in the shape of a parallelepiped (three dimensional rectangle) arranged in horizontal rows to achieve a checkered effect.
Opus segmentatum
: A mix of small and large tesserae creating a geometric pattern. Derives from a paving technique in which spare bricks were interspersed with shiny stones.
Opus signinum: Tesserae placed with space between them, in a geometric pattern, on a smooth pavement base made of powdered brick and lime.
Opus scutulam: Tesserae in diamond shapes arranged tightly.
Opus spicatum: Tesserae (often pebbles) laid in a herringbone pattern.
http://www.lifeinitaly.com/art/mosaic-technique.asp
Smitten
Well, this post puts my soul at ease!
It seems most members here, when referring to mosaic tile, are speaking of the smaller sized tiles that can be purchased in groupings pre-adhered to mesh for easier application.
When I think of mosaic tiling, I think of free-style shapes combined to create an over-all effect or design.
Both of course are correct.
Perhaps the difference is my art background. I have the need to be creative while still following the rules.
icclepiccle
I am about to start fitting mosaic files (ceramic) to teh shower cubicle (3 walls) in our en-suite. Never done these before and would really appreciate any tips on how to get it right first time. The mosaics come on sheets (30cmx30cm) and are about 4-5mm thick and 2.5cm squ each. I have got non-slip adhesive (waterproof) and a new trowel with smaller notches (triangular teeth about 3mm wide and same deep). I was planning on using a plasters float to carefully push them onto the adhesive-covered wall. Any hints/tips would be greatly appreciated. Just starting to get into DIY - did our bathroom this year and now doing our en-suite.
regards
icclepiccle:hurray::lol::grouphug::joker:
grumpygrouter
Hi icclepiccle, I note you say you are using "waterproof" adhesive. Please be aware that the only really "waterproof" adhesive is epoxy adhesive. I assume you are using a cement based adhesive for your shower area. You didn't say what the background is you are tiling onto but it would be very wise to "tank" (waterproof) the area if the substrate is susceptible to water damage, prior to commencing your tiling.
icclepiccle
Hi Grumpgrouter. I was planning on using the ready-mised Bal white star after talking to Bal yesterday. I'd rather not have to mix it myself due to the first tinme I've used mosaics. Substrates are: two walls of aquapanel that I fixed and jointed together plus the third wall being the original plaster wall (solid wall not partition). I have unibonded all three walls. Is this ok?
MTiler
Hi
I'd never use a tub adhesive for mosaics, they go off far to quick. You can get Mosaic Fix adhesive (BAL do one), but they can be expensive or an adhesive with a long working time and strong vertical hold, suitable for mosaics, so you can adjust the mosaics especially if you have to open or close the columns a tad. Nicabond and Mapei (P10) do good ones.
Obviously they take a bit longer to dry.
The hard epoxy grout floats are great for flattening the mosaic evenly. If you struggle working with whole sheets theres no problem with cutting the sheets into strips and sections, mosaics are very versatile.
On walls some people start at eye level with mosaics working horizontally, so the focal point is perfect, and then work down. The problem with that can be that when you come to do the top section you may get some lipping because of dried adhesive under the top row of tesserae. This may only be noticeable under certain light. So some say to work vertically from the bottom up using a vertical datum line.
Have fun.
MissyT
U
user123
i concur wholeheartedly,yes I'm an arty type too! just wish I could make a living at it!
Interesting that, isn't it Doug. I have been self-employed and doing my own thing since forever, (came to the UK as a technical translator) always working things out by myself, loving the intellectual challenge of discovery and the artistic calm inmy creative endeavours.
Now, realizing that if I want my mosaics to decorate individualistically minded peoples' homes, it's tiling I need and find I am fascinated by the whole subject, but still fired by artistic ideas, overflowing with them really. The thing is, I don't really like the artistic community so much, too much snobbery and ego and one-upmanship, whereas on here there is banter and trying to help each other and it's so nice, and I realize that by trying to follow my artistic bliss I have probably finally come across a network I don't mind networking with!
And I think my mosaics and the ever growing ideas can help you tilers, too, because by combining the two 'normal' tilers can add art expression to their customer service, (as in "you'd like some mosaic butterflies on your bathroom wall, madam? no problem, I know a woman who can...") and I can add good quality tiling to my service, ("well I could do you a jungle theme behind your jacuzzi and know just the tiler in your area to fit it..") I just don't think that kind of collaboration between classic tiling and freestyle mosaics happens very often yet.
What do you think to it all, having a foot in both camps so to speak?
U
user123
well you see, learning to tile I can marry the two to some extend on my own, but I have a secret weapon - the mesh I use is very fine, strong and flexible, much better to use than the ordinary mosaic tile mesh, which means even delicate mosaics can be posted safely and installed easily, I have it all worked out, see. There is a discrepancy of timing, but everything can be worked out, and most customers I am convinced would rather wait for the tiling to be done a week or two for the custom mosaic of their dreams to become a reality, so it's not such a big deal, it can be done, like everything where's a will, etc... You have no idea how strong all this is in my head...if trade is suffering then offering something unique will make the difference for everybody....:yes:
CJ
1,088
Somerset
Ah, but you might like mine - :yes:
Artistic mosaics is a time consuming job that the average tiler couldn't or wouldn't take on..........unless the customer had pots of ££££
I like the finished effect of mosaics.......as long as the substrate is spot on :thumbsup:
Mosaic Girl.............are you an ex "Art Student" type :grin:
U
user123
But that's the beauty of it, go back to #19 etc - the average tiler wouldn't have to trouble himself with the artistic bit, just install it within the other tiling he is doing - I'd do the arty bit...I had a request for a dolphin on a shower room floor via Dave not long ago - if you had a request like that, what would you do? And from my end, if someone said to me, can you do, say a lobster mosaic for behind the cooker, or a business name/emblem in the entrance hall, I 'd say, yes of course I could, and if the customer lived outside my immediate locality I could recommend one of you guys to install it, along with the other 'normal tiling' the customer would likely want doing - it's networking with extra service thrown in, giving people choice and options they may have thought is just for the chosen few who can afford designer prices....it doesn't have to be like that.
I like the finished effect of mosaics.......as long as the substrate is spot on :thumbsup: Agree with you there, that; why I'm doing the NETT course next week... you can have the most gorgeous mosaic, but if the finish isn't right only that will show, I am a perfectionist....
Nope, if you google my name my various professional hats come up and they still all apply to varying degrees...Jill of all trades:lol: but this tiling and mosaic malarky, well this has truly grabbed me ...with rapid set.......
Reply to Mosaic Technique and Construction in the UK Tiling Forum area at TilersForums.com
Hello I plan to tile our bathroom with 60x60 cm tiles (8 mm thick) and the shower (because of the slope from all sides) will be done with mosaic tiles (5x5 cm). After researching I came to the...
